Specialized Stumpjumper FSR Comp
Сообщение #240031 » 07.02.2013 21:42
Решил добавить в свою конюшню вот такой пепелац для трейла и гор самое оно)))), из ощущений катит лучше, чем скотт спарк 60, ну и обработка всяких там неровностей фоксом просто класс.
Сейчас вдуто в вилку 85пси /180 пси в аморт на вес 82 кг как раз нормально
Спецификация:
FRAME
FSR M5 manipulated alloy frame w/ Transform monocoque TT, sealed cartridge bearing pivots and rear shock mount, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 120mm travel
REAR SHOCK
Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.75x1.75"
FORK
Fox Float 130 RL, 130mm, rebound/compression adj, lock out, alloy steerer
HEADSET
1 1/8" Threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM
Specialized adjustable rise, OS 31.8, 3D forged w/CNC finish
HANDLEBARS
Specialized XC low rise 31.8mm OS bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 620mm width
TAPE / GRIPS
Specialized MTB, dual density
FRONT BRAKE
Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 185mm rotor, L/XL 203mm rotor
REAR BRAKE
Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 160mm rotor, L/XL 185mm rotor
BRAKE LEVERS
Avid Juicy 5
FRONT DERAILLEUR
Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
REAR DERAILLEUR
SRAM X-9, 9-speed, long cage
SHIFT LEVERS
SRAM X-7, aluminum trigger 9-speed
CASSETTE / FREEWHEEL
Shimano HG50, 9-speed, 11/34t
CHAIN
SRAM PC-971 w /Power Link
CRANKSET
Truvativ Stylo, 2pc crank/BB
CHAINRINGS
22S/32A/44A 4mm thick outer, 4 bolt 104/64mm
BOTTOM BRACKET
Truvativ GXP, sealed outboard cartridge bearing
PEDALS
Wellgo MG-1
RIMS
DT custom for Specialized X430, 24mm w/eyelets, 32h
FRONT HUB
Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
REAR HUB
Shimano M-525 disc, 32h, alloy QR
SPOKES
DT Swiss 1.8mm stainless, black, alloy nipples
FRONT TIRE
Scwable nobby nic 26/2,25 EVO
REAR TIRE
TUBES
Specialized Ultralight 26x2.12", presta
SADDLE
Specialized BG Rival, hollow Cro-Mo rails
SEAT POST
2014 butted alloy, black, 30.9 x 350/400mm
SEAT BINDER
7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
NOTES
Protective clear coat, derailleur hanger, reflectors, owners manual
gigant
Вел: ss
Сообщение #240033 » 07.02.2013 21:59
Красавец!
Надо in-action фото, а то в таком антураже вел выглядит неуютно
Сообщение #240034 » 07.02.2013 22:24
gigant, фотки конечно, ну Ты сам понял.
180 в аморт - любишь плюш? Какой аморт. Fox Rp23 или чтё ещё, понятно что как всегда со спешевской доработкой :)
Ну а так, коляско котадзэ и котадзэ :)
Сообщение #240036 » 07.02.2013 22:28
gigant, ухх, хорош. Но я б все же контактики поставил, или вынос короче и дабл :)
Сообщение #240037 » 07.02.2013 22:45
по аморту там стоит фокс триад, вдул 185 пси на вес 82 кг, мой 79 кг как по мне нормально, в вилку вдуто 85 пси под 84 кг,
если че потом можно для агресивного рейдерства вдуть 200/100 ну как по мне будет жестковато,
для себя пока выбрал 185/85 матрасный вариант
контактиники на лето поставлю, зимой лучше на топталках, вынос там 90 мм нормально, дабл не хо так как частые апхлы есть, нелюблю мучатсо)))
gigant
Вел: ss
Сообщение #240038 » 07.02.2013 22:45
по фото позже добавлю в полевых условиях фото
gigant
Вел: ss
